Aller au contenu principal
Mis sur le marché le 21 septembre 2018. Modèles A1920, A2097, A2098, A2100. Disponible avec GSM ou CDMA / eSIM ou dual-sim / 64, 256 ou 512 Go / Argent, Or ou Gris sidéral. (Se prononce "iPhone 10 S".)
398 questions Voir tout
brightness drops to 75% randomly
hello, i have replaced iPhones xs screen bought from ifixit (the OLED Packeg) replacement smooth and fine but i've noticed that time to time brightness off the display drops to around 75% (the top 25% won't do anything) and stays like that, seems pretty low and some time hard to see under sunny environments, reboot won't fix the issue but after sometime it fixes it self, is this a know issue? (BTW this 2nd screen replacement of the device first was done by Thirdparty and was working fine in these regales but had other issue which to me was a bad panel used by the shop even had bad fitting issues) this panel does not have such issue 3D touch is working fine too which wasn't working before. any idea what is causing this behaviour? BTW auto brightness works fine when this issue is not present.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
3 commentaires
How hot is the phone?
par
not hot normal temperature @areeve
par
that is what causing but phone is not overheating is slightly worm it use to get even hotter before and never had this issue even is display replaced.
par
Ajouter un commentaire
1 Réponse
Solution retenue
Screen dimming is part of the overheat protection, it is overheating or at least it thinks it is.
Indice 1
2 commentaires:
i will do the test again to make sure if this is causing, then after it turns to normal temperature it should go back to normal isn't it? then why doesn't it go back to normal?
par
@rokieride It doesn't think it has returned to normal temperature.
par
Ajouter une réponse
Rokie sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 9
Total : 77
