Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Sorti le 20 septembre, le smartphone le plus grand et le plus onéreux d'Apple en 2019 est doté d'un écran OLED de 6,5 pouces, d'un système de caméra à triple objectif et d'une autonomie de la batterie grandement améliorée. Successeur de l'iPhone XS Max.
iPhone 11 Pro Max not charging.
Hi all,
So I have this 11PM that has a dead battery (Which is Apple original), no problem I'll replace the battery. After replacing the battery I found that the device turned on but was stuck at 0% and not charging, it would also not show any battery information on 3uTools with the battery value and the ex-factory value both being at N/A, an indication that it is not reading information from the bottom connector.
After checking all the connections I tried a different battery from a different reputable supplier but have exactly the same issue. Both of these batteries give me all of their information on my jc v1s just not in the iPhone and thus although it does turn on it will not charge but it does still detect USB.
I should also note that the iPhone does not draw any current from a wall socket.
Any advice on next steps?
Thank you,
Tom
Répondre à cette question J'ai le même problème
Indice 3
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Sounds like a problem with the charge port (the original battery may not even need replacing) The phone only turns on because replacement batteries are usually (should be) shipped with some charge.
I can't explain the zero percent indication though, other than that there maybe issues with your replacement batteries.
Do you get the same result charging it via a wireless charger?
Indice 1
5 commentaires:
I would absolutely agree with this assessment. As for why it would be showing zero percent, bear in mind that the 11 Pro/Pro Max batteries actually have 2 connectors.
One goes directly into the logic board. The second, "south" battery connector, is part of a small daughterboard, which is essentially a part of the dock assembly. This daughterboard contains the charging chip itself. And battery sensor data needs to travel to that chip. So if there is damage to the flex cable that data can be garbled or can't get where it needs to. So the battery may misreport how much charge is left because it cannot communicate that information effectively.
par Partager
Yes wireless charging creates the same issue, I don't think it is the charging port because the phone does detect a charge because it says charged 0% but never goes up. It also connects to a pc just fine and allowed me to restore just fine as well. Like Alisha said i believe it is the south connection i'm having issues with as when the first connector is plugged directly into the logic board without the osuth connector connected the phone boots with the 0% issue. But when I connect the south connector, the phone will no longer even give me an Apple logo until I disconnect the south connector and then it will turn on with the issues mentioned above.
par Partager
Also, after you mentioned with the original battery I tried the original battery without the south connector attached and it booted up but with the same 0% and no battery information issue as with the other batteries and connecting the south port (With the device off and battery disconnected of course) the phone failed to boot once again, so thats 3 batteries 1 Apple original and 2 from different suppliers so I think I can rule out battery issues.
par Partager
My apologies! I've only just realised the daughterboard is attached to the charging port so yes I do agree that it is the charging port that's the issue. I'll order a genuine pull and keep you updated. Thank you for your advice!
par Partager
Well a new charging port didn't fix the issue unfortunately, still the same problems :( looks like mainboard issues I guess
par Partager
My 11pm is only charging by wireless charger I’m yet to take it in to a phone repair place I’m not sure if it’s the charger port I’ve cleaned it out but no luck it first died n I tried to charge it with no luck I ended up buying a wireless charger it works but it’s just slow compared to normal charger n I’m hoping to possibly find the problem by someone having the same problem or previously having this problem with some insight if it’s just bc i havnt cleaned it out properly but I think i did
Indice 0
Ajouter une réponse
Thomas Watson sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 28
30 derniers jours : 63
Total : 2,611
