No spark even after replacing coilpack and crank sensor
I have a fiat palio 1.6 16v, car was driving fine, just stalled on pull away and struggled to go up a ramp, i removed the throttle body to clean it with wd40 and the intake sensor. Put it back and then car did not want to start, checked for spark and there was none, i got a crank sensor from my friend who broke up a fiat palio and when i fitted it, the car started up and revved it up about 4 times. I then let it cool down and tried to start it again but again there was no spark, i went to purchase another one and still no spark, i then replaced the coilpack and yet no spark. There is power on the wires that plugs into the coilpack and crank sensor, i need help urgently. Does the 1.6 palio have a cam sensor and where is it located and can that also cause no spark.
Update (05/29/2022)
Its a 2002 as per the papers, i replaced the crank sensor and coilpack but yet no spark
4 commentaires
@ayyoob what year is your Fiat?
par oldturkey03
Did you check for blown fuses?
par F Dryer
There is nothing, i am going to take the ecu to an auto electrician to check whether the ecu is maybe faulty, but furthermore this car has me puzzled. This my first time having such a headache with car
par Ayyoob
I have the same problem, but havent replaced any parts yet.
hope to benifit from your investigztion and save some frustrations and time here, what was the final fix for your problem?
Thanks
par Byron
