Opened up Dualsense to fix drift, right stick now stuck going up
Hi,
I had stick drift that was unbearable recently, nothing could get it to stop so I decided to open up the controller and clean the potentiometers myself. Once I got that done and I even replaced the white thing inside the potentiometer with one from an old PS4 controller, I’m stuck with the right stick always going up. I’m not sure what I did wrong. I definitely didn’t break the green thing that latches onto the joystick since I barely moved it and I cleaned it pretty well. What could be the cause of this issue?
ViolentTubeGaming How did you clean it? Post some good picture of how this all looks and it'll help us to identify the " I even replaced the white thing" (wonder what you replaced there) and "the green thing"
Ajout d'images à une question existante You must edit your question to add images.
par oldturkey03
can u send me a pic plz i don't not have enough info maybe clean it with isopropyl 60% rated
par hay yew
@oldturkey03 hi, I added the images. The white thing is the circularish thing inside of the green ‘housing’ I’m not sure what they’re called. I definitely didn’t break it tho. All I’m getting on my controller is the right stick going straight up and even when I move it down it doesn’t register anything.
par ViolentTubeGaming
@hay yew I did clean it with the isopropyl alcohol but that’s not my issue here. It’s gone from normal drift to straight up just stuck going up all the time. I can’t move it down either.
ViolentTubeGaming how did you remove the white thing? That is all part of your potentiometer. Did you check with an multimeter to see if you still have variable resistance when you move it
par oldturkey03
Voir 4 commentaires en plus
