Aller au contenu principal
Pour réparer ensemble - Je crée un compte
L'Acer Chromebook 11 C732 est un ordinateur Chromebook commercialisé par Acer et faisant partie de la série Acer Chromebook 11.
How can I safely remove hot glue from the keyboard
A device came across my desk with hot glue under the keys. My guess is that the user had attempted to replace the keys that had fallen off. How can I safely remove hot glue without damaging the key switches? I'm using 91% Rubbing Alcohol but I'm having little success.
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
Ajouter un commentaire
2 Réponses
Solution retenue
use the heat gun man its safer
Indice 3
Hi
This is a hard one but if you are careful,I have had success removing hot glue from delicate things using a soldering iron but you have to be really careful
Hopefully this helps
Indice 2
2 commentaires:
Depending on how things go I might use this as a last resort. I'm gonna try using a heat gun on the lowest setting. Otherwise I want to see if there are any other methods.
par
Be very careful though using the hot air gun
Iv accidentally burned Apple Watch screens on their lowest setting with them
The reason why I said the soldering iron is because it’s much more controlled and isolated
par
Ajouter une réponse
Jacob Mehnert sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 15
30 derniers jours : 25
Total : 519
