Samsung s10 lite red tint issue
There is a red tint on the black parts of my screen how to fix it
This is a problem with OLED displays and has to do with the manufacturing process whether you get no tint red tint or green tint is basically the OLED lottery. However that said you may be able to compensate by going to Settings, Display, Eye Comfort Shield, and adjusting color temperature. And hope Samsung somehow addresses this in an update...
i tried this, it does not work
I have two issues...green brownish red and grey screen and also these are not tint...they are flickering colors on my phone meanwhile the flickering also goes on about horizontal lines appearing for fraction of seconds. I did factory reset, hard rest, wiping cache partition as well as installing OS again...none solved the problem. Only solution I could find is to change the whole screen panel which costs around 200 bucks or 17000 rupees. It is shame. Can't do an exchange for a new phone. Used for almost 2.5 years so can't send it to service center as warranty lapsed. Apparently, no solution at all.
The problem just developed on my phone as well. So yeah I have to get the screen replaced.
Dernières 24 heures : 4
7 derniers jours : 16
30 derniers jours : 81
Total : 1,573
No, it's mot dat case in my phone the red tint is oly visible at the black parts of my screen so u can say it as whenever the screen is black it's not fully black it will have a reddish ting
par amithesh y
Well; there are an awful lot of folks complaining about both red and green tint, a very few reported a factory reset fixed their device, some say that gave a temporary fix and others that a factory reset caused the problem. All I can suggest is to play with your available settings some report it only occurs using vibrant color mode. You can also try varying your day/night configuration. You can try a factory reset, remember to do a backup first and be sure you know your password and accounts first so tyou don't lock yourself out. As near as I can tell your only other option would be to spin the lottery wheel again and try another screen which might be worse. Note: I doubt it will make a difference but you could try a soft reset first hold power and volume down buttons at the same time until the phone reboots; about ten seconds, if it is a software issue that might fix it.
par Juan Garcia
Hi, I am using Samsung S10 lite, Even I'm facing the same problem
Red Tint Visible in all black areas, more easy to explain, when i set a black wallpaper, its dark redish grey
par Benny Wilson
@amitheshy did you get any solution for this, please advise me, even I'm facing the same problem
par Benny Wilson
