Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le 3a fait partie des téléphones Pixel troisième génération de Google. Cette version budget est équipée de la même caméra que les modèles phare de Google. Disponible en Résolument Blanc, Simplement Noir ou Violet. Mis sur le marché en mai 2019.
Device screen black after replacing battery
I've replaced the battery in my Pixel 3a, and even though it appears I reconnected everything, the screen continues to be blank. It vibrates when I use the fingerprint sensor and plug it in, so I'm not sure what's going on. I would take a photo, but this is my only camera.
I've also tried hard shutting down my phone and reconnecting the screen before turning it back on, with a similar lack of results.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Solution retenue
If you had to disconnect the screen ribbon I’d check the connector on the board and ribbon under magnification for damage. Also how did you remove the old battery? If you used something to lever the battery up there’s a chance pressure could of been put on the back of the display itself.
Indice 2
6 commentaires:
I removed the battery by pulling off one of the adhesive strips as instructed in the iFixit guide, then the other strip's tab pulled off without the adhesive, so I had to heat up the back of the phone and pry it off. The entire time, the screen was disconnected and set aside.
Also, checking both under magnification don't reveal anything that appears damaged.
par
Unfortunately sounds like the screen has been damaged during removal. I had to do a battery on the same phone last week and used heat and isopropyl alcohol to remove it, took a while as only inserted the removal tool a mm or two to prevent catching the side of the screen inside. Did you try the screen after removal to make sure it worked ok?
par
@strongbow I don't think I did, or at least before I replaced the battery. I guess I'll have to get a replacement screen, then.
par
Also did you disconnect the battery before anything else? Sorry just trying to rule things out.
par
@strongbow Yes, I disconnected the battery last.
par
Afficher 1 commentaire en plus
I was leery of even trying to venture into replacing the battery on my Pixel 3a, but then after watching the instructions and an youtube video, I ordered the kit. Carefully and cautiously following the instructions, everything went smoothly and slowly. When all was done and the battery was presumably re-charged, I immediately tried turning on the phone. And there was just a black screen and - nothing. That was a big disappointment, but I decided to re-try everything again, step by step, leaving the phone "to rest for a day". And then, when I tried to turn on my "dead phone" after two days of just "resting", it miraculously "revived". It's been working perfectly well since then (end of May 2024). Where was the catch? In my eagerness to triumph after "I did it", I oversaw the sentence about the "(re) calibration of the battery" at the end of the whole process. It takes (some) time and it happened during the "rest" period.
Arthur Shi's Guide is perfect, it should be read and followed carefully. In the case of my Pixel 3a I didn't have to apply heat (iOpener) to "open" the phone, just slowly and carefully used picks (labeled 1mm and 6mm with a Sharpie on picks). Thank you ifixit, thank you Arthur Shi.
Indice 0
Ajouter une réponse
Wayward Horizons sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 21
Total : 956
