Both triggers are stuck at 100% after diy repair of joysticks
After disassembling and replacing the left joystick of the xbox series controller, both triggers are now constantly fully pressed in according to software and the xbox console. However there is no mechanical difference in the triggers and their magnets. The joysticks works perfectly, and it appears that the triggers are the only issue.
The triggers worked fine before disassembly and repairing the joysticks. Any help would be appreciated :(
1 commentaire
Same problem happened to me, but all I did was replace the cover with a new metallic one. I did a little troubleshooting at the time, and the hall effect sensors on the triggers were not receiving any input voltage. :( I didn't find a schematic to see where that voltage comes from but I'll probably start working on it more tomorrow.
par Chris Fries
