Hi Justin,
I spent a bit of time poking around on the internet, and here's what I found.
First of all, it appears that model RCT6513w87DK is called a Galileo Pro rather than a Viking Pro; that may have contributed to your difficulty in finding a replacement screen.
I was unable to locate any screens using the manufacturing information (XianChuang M115WSBN40-03A), unfortunately. I did find that it appears the first three numeric digits of the model number are supposed to indicate the screen size; in other words, the "115" part of M115WSBN40 stands for 11.5 inches.
However, I did come up with a couple of them on eBay that should work. The search worked much better leaving off the last two letters DK from the model number. You'll have to take a look at them for yourself and decide if they're the right one.
RCA Galileo Pro RCT6513W87 11.5" Genuine Tablet LCD Touch Screen w/Battery
11.6'' LCD Display Screen for RCA 11 Galileo Pro RCT6513W87 Panel free ship #JIA
The first one is a complete display assembly with digitizer and battery (used), while the second is just the LCD itself; you were specifically asking to find an LCD, so I don't know if you need the digitizer as well or not. If that was the case, the digitizer is also available on eBay; it looks like it's running about $15 USD new like this one.
For RCA Galileo Pro 11.5'' RCT6513W87DK Touch Digitizer Screen Replacement
Hope that helps get you going again!
A voté
Annuler
Indice
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
3 commentaires
Justin Orange, do you have it apart already? Any markings on the back of the LCD? I hate RCA for using LCD's that are so difficult to find. I can find some for the RCT6303 but am not sure about compatibility.
par oldturkey03
Second @oldturkey03's comment; I had a laptop that I simply could not find an LCD for until I opened it up and found the manufacturer and their part number for the screen itself. After I had that I was able to locate several other devices that used that same part and ended up finding one that was used on a different laptop.
par Jerry Wheeler
@oldturkey03 I found on the back XianChuang M115WSBN40-03A. I also attached an image of the inside.
par Justin Orange
