Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Windproof and water-resistant, the Patagonia Nano Puff ® Jacket is made with warm, incredibly lightweight, highly-compressible insulation, and is ideal as either an insulating layer or outerwear.
How to remove sticker residue from a Nano Puff Jacket?
A sticker was put on the Patagonia Nano jacket and now the glue residue is on it. Is there a way to get the residue off?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
3 Réponses
Dry cleaners should know otherwise try contacting Patagonia. Another option is considering the various solvents like glue-be-gone, alcohol, acetone, etc. The risk of incorrect solvent use may be staining, dissolving material, and oily residue.
Indice 0
Isopropyl Alcohol works great. I would not use any Petroleum based products like Goo Gone, the oil will stain.
Using Isopropyl Alcohol, a clean rag, a little muscle and patience you can remove adhesive residue. If it is from Duct Tape be prepared to put some effort into it, but you can remove that adhesive as well.
Indice 0
Use a rubber eraser tool used for removing rubber cement. It will grab onto the adhesive and pull it off. It may take a bit of time.
Indice 0
Ajouter une réponse
twentyfivefrisbee sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 22
Total : 2,533
