Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Westpointe MDC 45AE est un déshumidificateur importé par Midea American Corporation.
water full light not going off
the red water full light stays on and i can not get it to go off. it sits there with the water full light on and will not actually come back on.
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
1 commentaire
I can't find the owners manual to this online, oldturkey03 may have one. If you have your owners manual look in it to see how the trigger for the water level switch sits in the bucket. Usually this happens when the bucket is drained and the trigger is not returned to the proper position.
par
Ajouter un commentaire
1 Réponse
Solution retenue
Is there an internal water tank? If so, check that it is correctly positioned inside the cabinet. Even if you have a constant drain setup, there will be a sensor or switch to confirm the tank is installed correctly. Perhaps this sensor/switch is damaged or jammed.
Also the compressor may have a time delay after the tank is installed - wait a while to see if it starts up OK
Indice 3
Ajouter une réponse
diana sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 13
30 derniers jours : 33
Total : 2,662
