Since you reset it, changed batteries, hard reset it and it still doesn't work this means there is something wrong with the motor. I have had 2 furbys that have done this before, The motor will sadly need to be replaced.
The small 6V brushless DC motor needs replacing. Here’s a guide that may help: Hasbro furby 2012 DC Motor Replacement
You could spin/jumpstart the motor or lubricate it. You can replace it with one from a PC DVD reader (this is the door opener motor). Shaft is smaller but it's ok, diameter is good. You need a solder iron as well to replace electronic part from DC motor. Once you get the 6V DC motor, you’ll need to solder it on the pre-existing motor wires....
I’m hoping this video I made, will help: https://youtu.be/UteznTOUegE
Also in one of your comments you say that the 6V Brushless dc motor makes all the wheels spin, but for some reason the furby still won't move. Maybe you could try wd40 lubricant on gears. Sometimes it gets stuck. If the gears/wheels are spinning then they may be out of place, and therefore need to be adjusted to make your furby move again.
It appears in the 2 videos that the lcd lights work which is good.
In the last video of your furby boom, the furby started doing the reset dance when talking. I have had 2 furbys that have done this before, after 1-2 weeks, they stop moving completely and the motor burns out. Since it moves up and down, then shutting off the motor is going in and out and will sadly need to be replaced.
If you would like you can always contact me at Oliviarepairs@gmail.com I will be able to walk through the process with you, but more in depth. I hope this helps! Thanks!
italiano version:
Dal momento che lo hai resettato, hai cambiato le batterie, l'hai resettato a fondo e continua a non funzionare, significa che c'è qualcosa che non va nel motore. Ho avuto 2 furby che l'hanno già fatto, il motore dovrà purtroppo essere sostituito.
Il piccolo motore CC senza spazzole da 6 V deve essere sostituito. Ecco una guida che può aiutare: Hasbro furby 2012 DC Motor Replacement
Potresti far girare / far ripartire il motore o lubrificarlo. Puoi sostituirlo con uno da un lettore DVD per PC (questo è il motore dell'apriporta). L'albero è più piccolo ma va bene, il diametro è buono. È necessario anche un saldatore per sostituire la parte elettronica del motore CC. Una volta ottenuto il motore a 6 V CC, dovrai saldarlo sui fili del motore preesistenti....
Spero che questo video che ho realizzato possa essere d'aiuto: https://youtu.be/UteznTOUegE
Inoltre in uno dei tuoi commenti dici che il motore 6V Brushless dc fa girare tutte le ruote, ma per qualche motivo il furby continua a non muoversi. Forse potresti provare il lubrificante wd40 sugli ingranaggi. A volte si blocca. Se gli ingranaggi/le ruote girano, potrebbero essere fuori posto e quindi devono essere regolati per far muovere di nuovo il tuo furby.
Sembra nei 2 video che le luci lcd funzionino, il che è buono.
Nell'ultimo video del tuo furby boom, il furby ha iniziato a fare la danza del ripristino quando parlava. Ho avuto 2 furby che l'hanno fatto prima, dopo 1-2 settimane, smettono di muoversi completamente e il motore si brucia. Dal momento che si muove su e giù, lo spegnimento del motore entra ed esce e purtroppo dovrà essere sostituito.
Se vuoi puoi sempre contattarmi a Oliviarepairs@gmail.com Sarò in grado di seguire il processo con te, ma in modo più approfondito. Spero che aiuti! Non sono molto bravo in italiano. Grazie!
A voté
Annuler
Indice
2
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
