My laptop is not turning on
My laptop power light is blink but nut turning on
Hey, if the power light is "blinking," there's a good chance the video card is damaged. Video cards are extremely sensitive, so be extra careful when working with it. Also, the RAM might be acting up. Check both of these things, and see if that solves the problem.
It's look like Motherboard problem. Mighbe EC bios failure or IO ic failure.
Go through a process of elimination. Remove the ram, remove any graphics card that may be installed, check the bios settings. One or more of the hardware items may be causing the issue.
Cuando busque de los posibles problemas mire que si parpadea con tiempo superior a dos segundos es daño en la cpu
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 22
Total : 417
Pranav Prajapati what have you checked? What have you tried to fix this?
par oldturkey03
