no dirt in upper tray
My roomba runs a full cycle but there is not dirt in the upper tray, the filter tray has dirt though.
Check for clogged passageway into upper tray and placement of upper tray over intake port from the lower portion.
jill, "This could be due to the unit’s fan being either plugged up or not spinning fast enough to pick up heavier dirt. If this happens, you can disassemble the back canister and clean out the fan chamber. You can also recheck the connections on the dirt tray. This dirt tray has a vacuum motor that assists the dirt flow picked up by the unit’s brushes." check on here for more info. Here is what the service manual recommends:"Verify the vacuum is unobstructed. Take out grill, spin impeller and shake out any dirt. Inspect the filter to make sure it is not punctured and letting particles into the impeller.
Verify the vacuum contacts are clean.
If sounds loud or is dead replace unit
Hope this helps, good luck.
I have just experienced that problem. There is a part that turns the brushes, (the brushes do not spin in mine). The part that turns the brushes is burned out. Some sort of motor. My roomba still runs, but does not pick up dirt. That is the solution to my problem. Fixing it is a question I have not found.
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 2,656
