Aller au contenu principal
Informations sur le démontage et la réparation du smartphone Android phare de Samsung, le S20, sorti en mars 2020.
Screen touch after glass replacement?
I have an S20 I want to repair. the screen is cracked and does not have touch in certian areas. Will I have to replace the whole screen or just the glass?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Solution retenue
Hi Jenna,
While it is possible to replace just the front glass, that doesn't address the problems with the digitizer you're having, as the two parts are separate. In addition, doing so requires special equipment and skills so as not to damage the OLED display, and a laminating machine is needed to bond the new glass to the LCD. Suffice to say that front glass replacement is beyond the capabilities of us home DIYers.
So that leaves us with replacing the screen assembly, and there you have two choices, with or without a frame attached.
The LCDs that come with the frame requires you to transfer all of the internal parts of the phone to the new frame, so it ends up being a lot of work.
With the ones that don't come with a frame, you have to carefully separate the old LCD from the existing frame and glue the new screen to the frame. It's a bit harder to get the old screen off, but you don't have to do all the parts transferring involved in replacing a frame.
Either way, there are guides available here on iFixit that will step you through the process from beginning to end. In order to replace it you'll need the model number, as there appear to be two different screens depending on whether it's a Verizon model or not.
Guide for screens with the frame (assumes the battery comes with it, but depending where you buy it, it may not).
Galaxy S20 Screen and Battery Assembly Replacement - iFixit Repair Guide
Here's the guide to use if you buy just the LCD without the frame.
Samsung Galaxy S20 Screen Replacement - iFixit Repair Guide
You can get the screen with the frame here on iFixit, or with or without it at several other vendors such as Amazon, eBay or AliExpress; whatever works for you.
Hope this helps, let us know how it goes.
Image Galaxy S20 Écran
Tutoriel
Remplacement de l'écran du Samsung Galaxy S20
Difficulté :
Difficile
45 minutes - 2 hours
Image Galaxy S20 Screen and Battery Assembly
Tutoriel
Difficulté :
Modérée
1 - 2 hours
Indice 2
Replace the screen with a new frame attached. Piece of cake to do, no faffing with removing the screen from the frame and trying to glue the new one in properly.
Indice 0
Ajouter une réponse
Jenna Williams sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 3
Total : 778
