Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La montre connectée quatrième génération d'Apple, avec connexion aux réseaux mobiles en option, mise sur le marché le 21 septembre 2018.
Removing a screen set with epoxy - tool advice needed
I know I screwed up big time, but here it goes.
Two years ago, I had to replace a screen on my S4. The replacement went fine. However, I did not have B7000 glue on hand. Feeling impatient, I used epoxy to set the screen. The repair held up fine; the problem is now I need to replace the battery.
What good prying tool would you recommend to dig through a layer of epoxy between the screen and the body of the watch? Of course, there will be acetone involved.
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Solution retenue
Vladislav Ekimtcov some isopropyl alcohol in a syringe with a blunt needle to try to soak the epoxy. After that some heat and the smallest dental pick you can find to try to gently scrape away the epoxy. It'll take a ton of patience.....
Indice 2
3 commentaires:
Thank you! Did not think the heat would help with epoxy, but seems like it will. How hot does it have to get?
par
@Vladislav Ekimtcov just try to get the epoxy „Tacky“ don‘t try to melt it since that may cause more damage. You‘d have to experiment a bit, so start with low heat. More of a steady warm…
par
Ajouter une réponse
Vladislav Ekimtcov sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 15
Total : 284
