Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Tutoriels de réparation, démontage et informations de diagnostic pour la première génération de la manette PlayStation 5 DualSense de Sony, qui succède à la série DualShock. S'identifie au numéro de modèle CFI-ZCT1W et à la carte mère modèle BDM-010.
What would cause a bumper button to not work
I have a PS5 Dualsense remote with a suddenly non-functioning R1 button.
  • No physical damage to the remote from dropping/excessive force has been exerted
  • No water damage
  • The black plastic part of the button is in the correct position. Removing to access the silicone part of the bumper button and pressing with a pry tool/screw driver does not work
  • R2, L1 and L2, as well as all other functionality is perfect
  • The remote is a v1 remote
I've tried disassembling the remote and investigating, nothing out of the ordinary to report and I'm at wits end. Any guidance would be appreciated.
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
3 Réponses
Solution retenue
Ended up being a microtear in the ribbon cable through some of the middle connections, which obviously affects the R1 button in particular.
Easy enough to replace, but I can imagine that with the design of the right ribbon cable being more exposed it could potentially lead to more issues over the left one
Indice 0
1 commentaire:
Had to buy a new L1 bumber it goes in normally & even works but won’t stay in the holder whatsoever. Falls right out when I turn controller upside down or tip it over confused tried everything what could it be ?
par
How do you fix the micro tear
Indice 0
1 commentaire:
Replacement ribbon cables can be found on Amazon. Watch for the generation controller you have though as apparently there are several and some use slightly different cables.
par
My L1 has the issue even after replacing ribbon cable with new one iam still facing the same issue don't know of it's hardware to software issue
Indice 0
Ajouter une réponse
Jarod Kurland sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 18
30 derniers jours : 55
Total : 6,548
