Wi-Fi working without Wi-Fi Antenna.
Hello!
I removed the Wi-Fi antenna located at the top right, next to the rear camera, and when doing a test I am still able to connect to Wi-Fi. Are there 2 Wi-Fi antenna in the iPhone 8 Plus? Or it the antenna at the top right only a GPS antenna maybe?
Thank you!
Edit : Added images and also where I found the guide https://www.sosav.fr/guides/mobiles/ipho...
8 commentaires
Hi @gabb04
Can you upload some photos using this amazing guide to show us what where about the antenna is so that we can help you find out what it is
Ajout d'images à une question existante
par HelloMacOS
@hellomacos Hello! Thank you for the reply. I added some images of the part and where it is located and also the website where I found how to remove it since I wasn't able to find it here. Thank you!!
par Gab
@gabb04 I second this, as I just looked at the schematics for the iPhone 8 Plus (Qualcomm version) and the top right most antenna connector is the NFC antenna
par Geir Ove Andersen
@gabb04 Ah, that one; Well, if you have a strong WiFi signal, or you're close to the WiFi router, it is quite possible to get a signal, even without an antenna connected.
@geirandersen Ahh I see! It makes sense! Thanks for the info.
Would I be possible to completely remove the Wi-Fi while keeping the cellular data? I know that there's the diversity antenna but I think this both has Wi-Fi and Cellular, but I am not sure.
par Gab
Voir 3 commentaires en plus
