Aller au contenu principal
The Sanyo VPC S1275 is a 12.0 mega pixel compact digital camera produced by Sanyo which is a subsidiary of Panasonic.
11 questions Voir tout
The "OK" button does not work
The "OK" button of my camera does not work anymore. Is there a way to fix it?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Solution retenue
Does it feel like it's somewhat stuck when you press it? If it does, give it a good cleaning by following the advice from this answer by Reed Crosby; you may also want to follow this replacement guide and open the camera (steps 1-5) to check if there's anything under the button preventing it from working correctly.
The button may as well be physically broken: to confirm this, first ensure the control panel buttons are in good condition, then complete said replacement guide and reassemble the device, apart from the function set strip. Now turn the camera on and test the OK btn, you can navigate through the menus by pressing directly on the control panel using a pointed tool like a pencil. If everything works, you just need to buy a spare part and replace it (or salvage for parts from a broken device); otherwise there's a more serious damage and the device needs to be inspected thoroughly
Hope this helps, feel free to ask if you have any more questions
Indice 2
2 commentaires:
Thank you so much for the help! And yes, it does feel a little stuck when I press it. I will try to open the camera to check what is causing the problem. It´sa really good camera and it would be a shame not to use it.
I´ll try to let you know if I can fix it!
par
@Francesca Glad it helped, of course feel free to post any updates and let us know how the repair is going
par
Ajouter une réponse
Francesca sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 13
Total : 132
