Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Informations sur la réparation du Xiaomi Redmi Note 8T, un smartphone sorti en novembre 2019. Ce téléphone porte le numéro de modèle M1908C3XG.
After changing display, there are problems
Well I successfully changed display to some from Chinese market one, but after changing display there are some problems now:
  1. Sometimes you have to press power button multiple times to wake up display
  2. Sometimes when someone is calling you, display won't react to touches and you can not pickup call.
What could be causing this?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
@playandwin from what you are describing, it sounds like a bad display/touch screen assembly. Of course, always double check your work ensuring all the cables are properly seated and the connectors are in good condition. Also try a reset so to rule out any software issue. If you ruled all that out, you know its the display assembly. Can’t repair that but would need another replacement.
Indice 1
2 commentaires:
Clean the motherboard with alcohol 90 degree
par
If you put a protection on the screen put it off
par
Ajouter une réponse
Lubik sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 11
30 derniers jours : 24
Total : 627
