Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Informations sur la réparation et le démontage du smartphone Google Pixel 6, sorti en octobre 2021. Identifié par les numéros de modèle GB7N6 et G9S9B16.
Pixel 6 touch screen less precise after replacement
I have had my Pixel 6 screen replaced after a big crack.
After finally fixing the fingerprint sensor issue, I still find myself with a major problem:
The touch screen is less "precise" when typing fast. Namely, when I am writing fast and touch the screen in two points almost simultaneously, it interprets it as a "swipe", and therefore misses the first of the two touches.
This had never happened before the change. Is this a known issue, or could it be a problem with the new screen itself?
Thanks!
Répondre à cette question J'ai le même problème
Indice 2
Ajouter un commentaire
3 Réponses
Réponse la plus utile
This is likely a defective screen. See if you can get a refund or replacement. If it was a cheap screen, it may just be very low quality.
Indice 2
1 commentaire:
Thanks, that was also what I thought. It was however not a cheap one, and was (according to the seller) an original piece. Will ask for a refund
par
I have this same issue and also when I call someone the screen flickers
Indice 0
Hi. I don't have an answer, but I also got my screen (only the touch part) replaced by a third party (Pixel 6 wasn't launched in India) and have the exact same issue. How did you fix it?
Indice 0
Ajouter une réponse
Davide Di Nello sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 23
Total : 1,176
