I'm answering this on the assumption you did the screen and battery replacement yourself. If you took it to a shop you should definitely return there and tell them it has a new problem since the work they did.
Anyway, my first guess would be misplaced screws. Were you diligent in making sure each and every screw you took out went back in exactly the hole it came out of? Long screw damage is a recurring thread for iPhone DIY repairs and occurs when a screw that's too long is inserted over a circuit board or flex cable and ends up drilling into and damaging it.
If that's not the case, then I'd probably look at the connectors next. That will mean opening the phone back up and removing the screen (with the battery unplugged, of course). Take a magnifying glass and a bright light and examine all of the connectors you've unplugged, both on the logic board and the cables themselves. You're looking for bent or missing pins; if you find a bent one you may be able to straighten it with some fine tip tweezers.
Finally, after assuring yourself all the connectors are fine, reconnect them, making sure they are all the way in their sockets, snapped in place. Remember to start the long ones on the ends, not the middle, as that can flex the connector and end up with damaged pins.
Put the covers back in place and reinstall the display. Personally, I'd skip the screen adhesive at this point in case you have to open it up again; if the issues seems to be fixed then you can reopen it and install the adhesive.
Test it out and see if the issue is still there; if it is, come back and tell us what you found and we'll go from there.
Sound like a plan?
A voté
Annuler
Indice
2
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
