BDH2000PL Device stopped working: will not turn on; no charging light.
Device will not turn on. No light when inserted on charging unit. No noises, lights, or any indication of what the problem is. Device was only used for 6 months and currently has a new filter inserted.
Indice
0
Mary Ross, have you taken it apart (enough) to test the internal battery? Some devices refuse to operate (and even accept a charge) if the battery is dead. Here is a link to the manual online (this is directly to the troubleshooting part of the manual).
If you can get access to the battery, use a DMM (digital multimeter) and measure the voltage of the battery. At the same time, measure the output of the charger to make sure it outputs the correct voltage.
par Geir Ove Andersen
