Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Tools for welding keyboard on new cover?
Hello,
I have to replace the covers of my hp laptop because it is broken . But I need to keep the keyboard itself and mount it on the new cover.
I would like to know which tool I can use to make the plastic welding? (See the attached picture pls)
Could you help please? Thanks.
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
Ajouter un commentaire
3 Réponses
Solution retenue
Hello,
So hereafter how I finally proceed.
To remove the keyboard I used a thermal blower. You have to move fast but it works well.
To mount in the new case I used a soldering iron along with bakering paper.
The soldering iron needs to be adjusted at the lowest so as not to be too hot.
The result is very close to the original.
HTH
Indice 0
Réponse la plus utile
Hi Rub B,
Yeah, this comes up frequently; there are a lot of manufacturers that attach their keyboards this way. It makes for a good connection between the keyboard and the case, but it's also a pain in the wazoo for those of us who have to replace one. I've dodged that bullet myself because I found a top case that came with the keyboard cheaper than the keyboard by itself, but I did look into it in preparation.
Generally there are two main methods of separating them; first is by using an X-Acto knife to cut the tops off, and the other is to melt them with a soldering iron. The X-Acto knife is cleaner, but the soldering iron tends to be faster.
As far as reattaching them, the quickest solution I saw suggested was with a hot glue gun. Place the keyboard down over the plastic stubs and everywhere there's a stub, put on a dab of hot glue. I'm told it worked well and held the keyboard securely. The approach I had intended to take was to get some of the leftover plastic rods from building a model car and using those as a kind of solder substitute to weld the plastic stubs with a blob of plastic back on top. The other thing I considered was finding a bunch of self-tapping screws small enough to go into the plastic and screw the whole thing down.
Those are the best ideas I came across; hopefully one of them will appeal to you and be workable for your repair.
Good luck; let us know how it goes!
Indice 4
1 commentaire:
Thank you very much Jerry for this smart recommendations and for taking the time.
I will consider them as serious fallback workarounds.
However, does anyone know how to weld close to the manufacturers way? Tools? Technics ?
par
I would agree with X acto knife if going to use the screw method.
I would not use the X acto knife way if hoping to heat up the area and pull up leaving some plastic sticking up... so the re-install you will have 'some plastic' to work with melting down onto the new replacement keyboard as to make a rivit. (each stud/hold down on the keyboard).
Tools to do this is a question. Do you have a heat station that is hot air? that seems to be a perfect suggestive tool to use. Going to have to move fast on each hole in removal as they seem close together.
OR
.. learn how to lift off each key you need, and replace each key separately :D
PS, Fixing downhill skies, we used " p tex " on a iron to drip hot drops of this plastic reson on to the holes and scrapes of the bottoms of skies. Then ran the skies over a belt sander to smooth out the surface. It was a perfect way of fixing skies.
Search for : " p tex ski repair "
Indice 0
Ajouter une réponse
Rub B sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 22
30 derniers jours : 104
Total : 2,525
