Aller au contenu principal
Floor lamps are lights that sit on the floor. They are not table lamps, which are designed to sit on tables. Floor lamps are usually taller than table lamps.
Questions au sujet de 17 Voir tout
How do I fix a lamp with a short? The bulb flickers on and off.
my floorlamp bulb flickers on and off and only holds a light if balanced in a specific position. i think there is a short in the connection. how to fix?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Just try replacing the lightbulb 💡
Indice 1
2 commentaires:
I tested the bulb, of course, on another fixture. It's fine. And the lamp is plugged in.
par
Then I guess you should consider replacing the lightbulb socket, but can’t say more specifically until we see an exact unit
par
@mcb48 if changing the bulb does not help you may need to check the wiring in the light fixture itself. Remove the bulb (unplug your lamp) and take a picture of where the bulb normally sits. And one of the bulb itself. that way we can see what fixture your lamp has and hopefully can be more specific with our answer.
Indice 0
Ajouter une réponse
Mary Borrelli sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 21
