Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Repair and service information for Western Digital Elements external storage drives.
Western Digital Elements HD Make a sound like Tik Tik Tik
My Western Digital Elements HD Make a Sound as Tik Tik TiK after connected to laptop and Not recognized
please your help
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
Ajouter un commentaire
1 Réponse
Solution retenue
Abdul-Rahman Salem this is most commonly indicative of a Hard drive error. The ticking from the drive means that is has an internal problem which is commonly known as "lost servo". The ticking sound is the search arm going back and forth. Check the BIOS on your laptop to see if the drive still shows up on there. You can always try a new cable, check the drives connection in the external case. Sometimes, replacing the HDD controller board can repair this. Ultimately, it sounds like your drive has failed.
Indice 1
2 commentaires:
Although it is considered new, I don't know why this is happening
My goal is to transfer the data on it
is there a solution ?
par
@Abdul-Rahman Salem you can't, since it is not working. There is no software for this and do not consider opening the drive either. If the files are important to you, try a data recovery specialist (expensive) to recover those. There is no other way.
par
Ajouter une réponse
Abdul-Rahman Salem sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 12
30 derniers jours : 55
Total : 873
