Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Tutoriels de réparation, informations sur le démontage et diagnostic pour l'iPad 7e génération d'Apple avec Wi-Fi, disponible en 32 ou 128 Go de stockage. Sorti en septembre 2019. Identifiable par le numéro de modèle A2197.
Screen ghosting/Shadow on Led.
I cleaned the lightning port with electrical contact cleaner, worked great.
now the LED screen appears to have some ghosting/shadows behind the image. never had this issue before.
Is this fixable? or do i need to replace the LED.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Hi Oliver,
Depending on how heavily you doused the port with the contact cleaner, it's possible some of it made its way inside and got onto the LED/backlight/polarizer assembly. We've seen cases where a similar thing happened with isopropyl alcohol, and luckily after a couple of days the alcohol finally evaporated and left the screen okay.
In your case I'd suggest giving it some time to allow for the cleaner to dissipate; it may fix itself all on its own. If it still looks like that in a week then it might be worth considering a screen replacement.
Let us know what happens; if it doesn't clear up on its own, add some pictures to your question of what you're seeing and we'll see what we can do for you then.
Indice 1
The first thing you should do if you're dealing with the ghost touch issue is to force restart your device. This will refresh the memory and reload all services. Needless to say, it brings your iPad back to its normal operation.
Regards,
Will
Indice -1
1 commentaire:
@willjoe it’s not a touch issue it’s an image issue.
par
Ajouter une réponse
Oliver Byrne sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 19
Total : 545
