Aller au contenu principal
Pour réparer ensemble - Je crée un compte
The Samsung Galaxy A10s is an Android smartphone developed by Samsung Electronics, and was released in March of 2019.
Why is my wifi and bluetooth not working
Why is my wifi and bluetooth not working Why is my wifi and bluetooth not working
Répondre à cette question J'ai le même problème
Indice 111
30 commentaires
Has the phone been dropped or damaged at all?
par
I did factory reset but still not working
par
I went in my hardware but my wifi and bluetooth are not listed in and its says unavoidable
What must I do
par
I'm having the same issue on my Samsung Galaxy Note 20 Ultra. After the new update, they both stopped working.
par
Check (verify) the time zone on your phone. I had this problem On the last update and resetting the TIMEZONE corrected the problem.
par
Voir 25 commentaires en plus
Ajouter un commentaire
34 Réponses
Réponse la plus utile
There could be several reasons why your WiFi and Bluetooth are not working on your Samsung Galaxy A10s. Here are a few things you can try to troubleshoot the issue:
  1. Restart your phone: Sometimes, a simple restart can fix minor software issues.
  2. Check if the WiFi and Bluetooth toggle switches are on: Go to Settings > Connections and make sure that the toggle switches for WiFi and Bluetooth are turned on.
  3. Check if the WiFi and Bluetooth chips are enabled: Go to Settings > About phone > Hardware information and make sure that the WiFi and Bluetooth chips are listed as enabled.
  4. Check if there are any software updates available: Go to Settings > Software update and install any available updates.
  5. Check if there are any issues with the router: If you're trying to connect to WiFi and it's not working, try connecting to a different WiFi network to see if the issue is with the router.
  6. Reset the network settings: Go to Settings > General management > Reset > Reset network settings. This will reset all the WiFi and Bluetooth connections on your phone.
  7. Factory reset your phone: If none of the above solutions work, you may have to perform a factory reset of your phone. Keep in mind that this will erase all the data on your phone, so be sure to back up your important files before doing this. To factory reset your phone, go to Settings > General management > Reset > Factory data reset.
Indice 28
37 commentaires:
I did factory reset but it still doesnt wrk
par
Hi I did all but didn't work
par
After the last Samsung update my wifi and Bluetooth isn't working as well
par
Same for me, bluetooth and wifi can't be on. when I tried to open it it'll become off again.
par
Same here to me
par
Voir 32 commentaires en plus
الخلل في ايسي بلوتوث والحل استبدال الايسي او تسخينه راح يرجع الجهاز طبيعي
Google translate:
The fault is in the bluetooth eSee, and the solution is to replace the eSee or heat it up, and the device will return to normal
Indice 10
12 commentaires:
how to replace the esee or heat it up?
par
Oh my gosh I did everything but still won't connect I'll just chill here and wait for the answer
par
I am facing the same problem. My Wifi and Bluetooth is no longer working. Is there any Samsung Technician ca help me fix this problem? Thankyou.
par
I am also facing this issues wifi and Bluetooth devices is not working plz tell me solve the solution plz
par
Even if I refractory doesn't work
par
Voir 7 commentaires en plus
If your WiFi and bluetooth not working it is because of Ic problem you have to change it
Indice 8
2 commentaires:
I did perform factory reset but still the same. Help me out pls
par
How can we replace Or heat it where it is inside the phone?
par
If you have WhatsApp installed. Try cleaning WhatsApp data or uninstall WhatsApp. It works fine for me. A10S
Indice 4
4 commentaires:
It's a hardware issue. The phone's IC has a problem that's why the Bluetooth n WiFi don't work. The technician will demand approximately R250 to R350 to fix it.
par
No hardware issue this is new update issue.
par
Not an update issue. My phone has not received an update in years because it an old phone (Galaxy J5 prime). So it is a hardware issue-
par
My Samsung a10s have the same problem
par
turn on bluetooth to connect to nearby devices
Indice 4
1 commentaire:
Still my phone doesn't want to open
par
Reset your Wi-Fi router. The location of the reset button depends on what Wi-Fi router you are using but every Wi-Fi router has one.
Indice 3
1 commentaire:
Thank you, Anthony, but this is not a solution to problem.
par
Why is my wife and Bluetooth working
Indice 3
Try to format your phone
Indice 3
Heat ic 300 ⁰c but how can i show the ic
Indice 2
Well I will suggest to do the software update or system updated of your phone. Sometime outdated software version can also cause these kind of issue as well.
Indice 2
3 commentaires:
You can't update phone without WiFi
par
Even if I restart don't enable and not op6
par
I did restart but still is not working
par
Its hardware issue my 2 devices one got resolved heating ic and second one had replaced ic MT6631N
Indice 2
Wifi end blootot hospot
Indice 2
WiFi not opening
Indice 2
1 commentaire:
Since the problem occurred with all users of this version of Samsung, this means that its function was stopped in the latest Samsung update.
par
My wife and bluetooth are not working on my phone my phone is Samsung A10s
Indice 1
Indice 1
Bluetooth 11
Indice 1
1 commentaire:
WiFi and Bluetooth connection is not working
par
I have an S20+ and a WiFi 6 home network. I'm running the May 2023 update to OneUI 5.1.
Suddenly last night I was unable to connect to my home WiFi network. WiFi worked fine for all my other devices. I did lots of Google searches.... After trying all the obvious simple things (toggling Airplane Mode, Rebooting the phone, etc.), I looked in the S20+ Settings / Developer Options this morning and found "WiFi non-persistent MAC randomization" and turned it ON. WiFi almost instantly started working again on the phone.
I hope this helps others.
Cheers,
Scott.
Indice 0
My wifi and bloototh not working
Indice 0
My wifi and Bluetooth malfunctioning since last 2 months
Indice 0
Why my wife and bluetooth not working on network
Indice 0
5 commentaires:
par
My bluetooth and wife are not working my phone is Samsung A10s
par
Me 2 my Samsung A10s is not working
Bluetooth, WiFi and hotshot won't connect
par
My wifi and bluetooth not working
par
My Wifi and Bluetooth is not working in Samsung s20+ and developer option is also turned off
par
Indice 0
My wifi & bluetooth not working, I have samsung Fold 3… .I got sick of samsung, Im going to buy Honor magic v3
Indice 0
Wifi Bluetooth not working why problem factory already but not solve
Indice 0
Why Bluetooth say disconnected
Indice 0
1 commentaire:
Answer me plz
par
I do no but it's is in software complaint
Indice 0
How i can fixit
Indice 0
Indice 0
I don't no but I want to learn
Indice 0
f your Wi-Fi and Bluetooth aren't working, start by restarting your device and router, and check for simple issues like interference or drivers being outdated. If those don't work, try resetting your network settings, which will erase saved Wi-Fi passwords and Bluetooth pairings but can resolve connection problems. For persistent issues, consider updating your system or, as a last resort, performing a factory reset.
Indice 0
Replace or shake the wifi and Bluetooth IC
Indice 0
Replace the ic
Indice 0
Bluetooth isn't working my phone and isn't captured in songs
Indice 0
S20 not work Wi-Fi
Indice 0
Why is my wifi and Bluetooth not working
Indice 0
Ajouter une réponse
Yidnekachew sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 77
30 derniers jours : 405
Total : 80,425
