Aller au contenu principal
50" UltraSlim 1080p rear-projection DLP HDTV
Questions au sujet de 4 Voir tout
Samsung HL-T5076S DLP TV Restart Loop
I have an ancient Samsung HL-T5076S 50" DLP TV which has been working perfectly until recently. In the last month, it has begun to randomly have a restart loop during playback of anything. Tried plugging into different outlet with same result. Did some research on the internet and came to the conclusion it might be failed capacitors in the power supply unit. So I opened the TV and saw that the 22uF 250V capacitor was bulging with brown residue on the top - obviously bad. I bought a replacement Nichicon capacitor with the same 22uF 250V specs and replaced the cap. Also did a thorough cleaning of the unit top to bottom as there was quite a bit of dust buildup throughout. Replacement was quick and easy but I'm still having the same problem - random reboot, no different than before cap replacement. The rest of the caps on the power supply board look fine - no bulging or residue. Any idea what I should try next? Should I go ahead and replace the rest of the capacitors and see if that works? Or is it possibly something else?
Edit: also want to add that just before it restarts randomly, the screen goes to a bit of a yellowish tint and then to black as it restart.
Edit 2: Add images of the original capacitor
Edit 3: Add video off TV shutting off with back open - does this about every 2 minutes or so now
Edit 4: Add board images
Répondre à cette question J'ai le même problème
Indice 1
10 commentaires
Do you still have the old capacitors?
par
I only replaced one of them as mentioned and yes I still have it.
par
@dlp2022 Can you take a picture of all of the writing on the old capacitor and upload it here? Ajout d'images à une question existante
par
Added the requested images
par
@dlp2022 Where did you get the new capacitors? Do you have an ESR meter?
par
Voir 5 commentaires en plus
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Let me guess. the one you replaced is the one top left :-) Looking that this board I would strongly suggest that you replace all of the caps. Your Capxon capacitor are not high quality. Those were bottom shelf when they were first used. Those are really dodgy. Again, look at the temp marking on those caps. They are low quality 85deg which is really low and will lead to early failure. Replace all of your caps. I'd recommend some Nichicon, Rubycon or ELNA caps and nothing lower than 105C on the temp.. Clean your board up nicely with some good isopropyl alcohol and a soft brush. Check the diodes that I could see and mark (as well as others that I can't see) Do not forget to turn the board over and check for cold solder joints. Those are visible because there solder pads will be dull and grey compared to the rest. Sometimes a quick reflow will help. After that, re-evaluate.
Indice 1
17 commentaires:
Yes, good guess :) I will replace all of the Capxon electrolytic caps with new 105C ones and report back. Will also test the diodes once figure out how (have never done it before).
par
@dlp2022 for the diode testing check for something like this https://www.fluke.com/en-us/learn/blog/d... Let us know how it works out. New caps should make a big different on this set.
par
@oldturkey03 - I finally received the Nichicon caps and replaced them all today. Same result - nothing is changed. Is it possibly the bulb? I have not had to replace the bulb since I purchased the TV in 2007. I'm getting close to calling it unfixable and moving on.
par
@dlp2022 all the caps replaced, board looking good? At this point you are all in. I dont see that replacing the bulb would be a bad thing to do. Go for it and let us know. It would be unusual but anything is possible. Let us know how it works out.
par
Board looks good. I wouldn't say I'm all in, caps only cost me about $20 :) It's been a good run with this set but probably time to move on. Thanks again for the help.
par
Voir 12 commentaires en plus
Ajouter une réponse
dlp2022 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 239
