Why are my amps jumping
I bought a broken Nintendo switch online, it just needed a new charging port cause the pins were bent. I plugged in a good working battery before this and it turned on perfectly. After doing the repair all seems well but the Amps jump to 0.2 then 0.17 then to 0. I heard online it could be caused by not cleaning up the flux which I didn’t (I’m not home so I can’t test this theory) also I don’t have a microscope yet (comming friday) so I can’t fully tell if there’s a bridge in the pins. What’s this most likely to be. Did I mess up the board or was it just a bad job
2 commentaires
Hang on until your microscope arrives. It’ll be hard to see properly without one. I just bought one and makes the world of difference. Are you using the official charger to charge it?
par [deleted]
Using my own but thanks anyways I got everything sorted
par Daniel Caminero
