Aller au contenu principal
La Super Nintendo Entertainment System (SNES), ou simplement Super Nintendo, est une console de jeu 16 bits lancée par Nintendo en 1990. La Super Nintendo était l'une des meilleures ventes de son époque et compte encore aujourd'hui beaucoup de fans.
105 questions Voir tout
Why is Super Mario World missing assets/wrong colors?
The game boots fine, but colors are switched and Mario is a little jumble of demon text. The game functions perfectly fine, just an eyesore. I've tried cleaning the contacts, processors, and console, but nothing has changed. I've even tried re-flowing the cartridge. Any ideas on how to fix this?
Répondre à cette question J'ai le même problème
Indice 1
1 commentaire
Other games work perfectly fine by the way.
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi
Iv seen things like this happen on gameboy cartridges and it id usually due to ether damaged traces on the PCB, Loose pins on a Chip or corrosion
The best thing you can do is open the cartridge
Here’s a disassembly guide for that:-)
https://m.youtube.com/watch?v=raw6ve2fcr...
Once opened make sure that all chip connections are good ,make sure there’s no corrosion and the PCB looks to be in good condition
If any corrosion is found ,isopropyl alcohol is a good cleaner
If any loose pins are found you can resolder them back to the PCB
And if any traces are damaged a jumper wire will need soldered to close the gap:-)
Hopefully this helps
Any questions please ask
Indice 1
Ajouter une réponse
Daniel Cooper sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 50
