zoe m (Zoooeee) The myth of rice as a tool for any kind of immersion accident has long been laid to rest as totally bogus. Rice does not work. It is the equivalent of doing absolutely nothing. Stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse.This may further damage your phone.
The next thing to do is to clean it. Disassemble your phone using these guides. You must remove all EMI shields. If you do not remove those, you might as well not do anything. After you remove those, clean the whole board, connectors and all with +90% isopropyl alcohol. Follow this guide, and even so it was written for a iPhone 3G all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your phone and reevaluate. Until it is cleaned, everything will only be a guess. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
Translation
zoe m (Zoooeee) Le mythe du riz comme outil pour tout type d'accident d'immersion est depuis longtemps enterré comme étant totalement faux. Le riz ne fonctionne pas. C'est l'équivalent de ne rien faire du tout. Arrêtez de continuer à essayer de charger, synchroniser ou utiliser votre téléphone. Cela risque d'aggraver une situation déjà mauvaise et d'endommager davantage votre téléphone.
La prochaine chose à faire est de le nettoyer. Démontez votre téléphone en utilisant ces guides. Vous devez retirer toutes les protections EMI. Si vous ne les retirez pas, c'est comme si vous ne faisiez rien. Après les avoir enlevés, nettoyez toute la carte, les connecteurs et tout le reste avec de l'alcool isopropylique à 90 %. Suivez le ce guide, et même s'il a été écrit pour un iPhone 3G, tous les points sont pertinents pour votre téléphone. Pendant que vous nettoyez votre carte, vérifiez s'il y a des dommages évidents, comme des composants brûlés ou manquants, etc. Lorsqu'elle est correctement nettoyée, remplacez la batterie. Toutes ces étapes ont pour but d'éviter une panne différée causée par la corrosion. La meilleure chose à faire serait de la nettoyer avec un nettoyeur à ultrasons, mais si vous n'y avez pas accès, ceci vous aidera au moins. Une fois que tout cela est fait, réassemblez votre téléphone et réévaluez-le. Tant qu'il n'aura pas été nettoyé, tout ne sera qu'une supposition. Même avec tout cela, les dégâts causés par l'eau n'ont que peu de chances d'être entièrement réparés, mais vous pouvez au moins essayer.
A voté
Annuler
Indice
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
