Aller au contenu principal
Lancé le 20 septembre, le smartphone 2019 d'Apple est doté d'un écran OLED de 5,8 pouces, d'une caméra arrière à triple objectif et d'une autonomie de batterie considérablement améliorée. Il succède à l'iPhone XS.
20 questions Voir tout
Physical Dual sim iPhone conversion from single sim and esim.
Can I change my iPhone 11 Pro SIM card reader from single sim & esim to physical dual sim by just changing the existing SIM card reader to a physical dual sim one.
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
4 Réponses
Réponse la plus utile
It is possible. But the conversion is not as simple as just swapping the SIM reader out. It is soldered onto the board in this model and you would need to disable the eSIM so the phone will not utilize it.
This requires splitting the two layers of the logic board and removing some components in addition to swapping out the eSIM
Indice 2
Hi
I don’t think this is possible for 2 reasons
1)the sim card reader is soldered to the logicboard so if you would need good soldering experience to replace it
2)knowing apple they probably have this locked down as they have a quite the history of locking parts to the device to adding functionality is probably something that they are all over;-{
Hopefully this helps
Any questions please ask
Indice 1
1 commentaire:
The sim reader is held in with screws and not soldered in. You can buy dual sim card readers online but it may not work. Take a look on YouTube. I'm sure there's a guy put a video on about it. Maybe Hugh Gefferies.
par
Check online
Indice 0
For 11 pro, this is an advanced level modification, soldering required to replace the SIM tray and modification of ID resistors.
If you need to ask at this point, you are not the right person to perform such modifications.
Indice 0
Ajouter une réponse
Sundeep S Bhosle sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 1,028
