Dryer works for about fifteen minutes then shuts off.
Dryer will run and heat fine for about fifteen minutes then shut off and won't come on period like it has no power. Changed cord,plug outlet and checked breakers none are the problem
6 commentaires
@nicki86 "won't come on period like it has no power" it will not come on ever or you have to wait? Anything you have to do to get it to come back on? What complete model number is your dryer?
par oldturkey03
It will eventually come back on hours later and the process repeats. Model number 81022900
par Alicia
@nicki86 it sounds like it is overheating, the high limit thermostat turns it off and then when it cools down it does it again. Download the tech sheet from the bottom of this page and run the diagnostics test. Let us know what you find out
Kenmore Elite HE3 Dryer
par oldturkey03
Dryer will work fine on air fluff probably because it's using no heat. I will run test tomorrow but thinking it's one of the thermostats or heating element starting to go out.
par Alicia
@nicki86 those are good things. I love it when things just keep working again. Who knows.... maybe just blocking the outlet and it got hot etc. Use is for as long as you can and if it poops out again, we'll deal with it then. For now, you at least have a bit better handle on things, and you can always come back and restart this :-)
par oldturkey03
Afficher 1 commentaire en plus
