Aller au contenu principal
The Lenovo IdeaPad 110-15ISK was developed in the United States by Lenovo in 2015. The Lenovo IdeaPad 110-15ISK can be identified by its model number: 80UD.
10 questions Voir tout
Why is my laptop running slowly?
My Lenovo IdeaPad 110 keeps running slowly after update, why?
Répondre à cette question J'ai le même problème
Indice 0
4 commentaires
Hi Emma,
What did you update?
par
I updated my windows
par
@emilianocyril Which version? 7? 8? 10? 11?
par
It's version 10
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
How to Fix a Slower Windows 10 After an Update
Note: all the commands below take a while to run so go fix a tea or coffee while they are running. Good luck.
1. Roll Back the Most Recent Windows Update
To uninstall your most recent update:
Settings > Update & Security > Windows Update > View update history.
Next, click on Uninstall updates. Look at the list of installed updates. Uninstall the update you just did. If that doesn't help try next one.
2. Repair Corrupt or Damaged Files
System-critical Windows files might be corrupted or damaged and cause slowdown issues in Windows 10.
Try the System File Checker tool following the steps below:
  1. Go to the Start menu search bar, type in 'command prompt'.
  2. Run the Command prompt as an administrator by right-clicking the search entry and clicking Run as administrator.
  3. You will see a black screen with white text. In the Command prompt, type sfc /scannow and hit Enter.
After the scan is complete, reboot your system. If a recent update did cause any corruption, this should fix it.
If that didn't work try:
  3. In the Command Prompt type DISM /Online /Cleanup-Image /CheckHealth and hit Enter.
  4. If there are no corruption issues, you can run a more advanced scan using Dism /Online /Cleanup-Image /ScanHealth
  5. If you find corruption issues through the above step, run the Dism /Online /Cleanup-Image /RestoreHealth command to download and replace the damaged files. Restart your computer after the command gets executed, then run the SFC command again to repair any errors.
3. Disable Background Apps
Unnecessary background apps can cause Windows 10 to slow down after an update. Try disabling them to see if that fixes the problem.
  1. Open the Windows Settings.
  2. Then, click on Privacy > Background Apps.
  3. Choose which apps can run in the background section by turning off all the unimportant apps.
Let us know how it goes.
Indice 1
Ajouter une réponse
Emma Zain sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 32
Total : 208
