Aller au contenu principal
Mis sur le marché le 21 septembre 2018. Modèles A1921, A2101, A2102, A2104. Disponible avec GSM ou CDMA / eSIM ou nano-sim / 64, 256 ou 512 Go / Argent, Or ou Gris sidéral. (Se prononce "iPhone 10 S Max".)
Questions au sujet de 324 Voir tout
iPhone XS Max lags after replacing the charging port
Today my iPhone XS Max has a charging port problem, it was a hardware failure so i had to replace it, and after replacing the charging port from the dead iPhone XS Max, it has lag problem again after reboot, But when I plug it in, it's back to normal.
So is there any way to fix it? I find it rather odd because the charging port is from XS Max anyway, not OEM at all
Edit: it shut down after a few minutes and i still don't know how to fix it
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
The lagging sounds more like a battery issue than a charging port issue, the phone will throttle itself so it uses less power if the battery can't supply the power the phone needs anymore. Have you already tried replacing the battery with a good-quality replacement?
Indice 0
1 commentaire:
I didn't try, maybe I should. Thank you for that, I will reply as soon as possible.
par
Ajouter une réponse
Kiyoshi sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 36
