Aller au contenu principal
Introduite en 2016 lors du lancement de la Xbox One S, la manette Xbox One ajoute le support Bluetooth pour Windows 10. C'est la manette grand public actuellement vendue par Microsoft. Elle rectifie un nombre de défauts de conception des manettes modèles 1537/1697 et elle est beaucoup plus fiable.
xbox 1 controller RB, LB, X, Y, A, Dpad, and menu buttons not working
please help, almost all the button don't work. I've cleaned the contacts with isopropyl alcohol and replaced the rubber contacts. Only the analog sticks(with click), B, LT, and RT work
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Solution retenue
The bottom motherboard is responsible for all of the buttons you mentioned. Replacing this part will most likely fix your buttons. It is odd that your controller has power, though. The micro-USB port is also on the bottom motherboard. If your controller works plugged in, then I suspect that the exact problem is a couple faulty pins in the connection between the bottom motherboard and the upper one. Visually inspect the pins on the square connector that connects the two boards to make sure that there is no visual damage or discoloration on the top board (since you're replacing the bottom one). If the top board looks intact, then I highly suggest replacing the bottom board.
Image Replace a motherboard for the (1708) controller compatible with the Xbox One S video game console. Fix issues like a corroded or damaged motherboard.
Produit
Xbox One S Controller (1708) Motherboard
$14.99
Indice 2
Ajouter une réponse
rwtechrepairs sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 42
Total : 1,387
