Aller au contenu principal
Le premier modèle d'iPhone, modèle A1203 avec 4 ou 8 Go de stockage, et coque en aluminum. Les réparations sont souvent basées sur le principe du levier et peuvent demander de la soudure quelques fois.
20 questions Voir tout
Help! iPhone stuck in boot loop with weird shadowing on screen
im planning on replacing the display, just need to find a part with a digitizer and lcd with all the small parts
it only turns on when its plugged in as shown in the video, and has a weird shadowy affect after it turns itself off.
anyone know what to do?
ive tried putting in in dfu mode while its doing this,hard resetting also, and it doesn't help
is this also a display issue/recovery issue or is it something else?
I GOT TO GO INTO RECOVERY MODEEEEE
okay but is it compatible with the newest itunes update?
what do i need to do to actually recover this phone?
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Réponse la plus utile
are you concerned about data on the phone?
if not, then i'd recommend downloading 3utools and installing it on your PC. put the phone into DFU mode (you will need to google how to do this for your model), connect it to your PC and execute a anti-recovery Flash.
this will install the latest firmware and IOS for your phone.
this usually works for me when i get bootlooping phones to evaluate - but only if the data is expendable.
Indice 1
3 commentaires:
@beekerc
is there a version for mac?
also i don't mind the data, i bought this phone off ebay to repair
par
also the phone turns off before i can put in dfu i only can barely get recovery mode to work in time before it shuts off it only stays on for about 10 seconds before turning off:(
par
@timtomissus
no. 3utools is for pc only, sorry
par
Ajouter une réponse
timtom77 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 8
Total : 169
