Portafilter - Busted and probably unfixable... need suggestions.
So I bought that little L-spring to fix my portafilter and discovered that a peg seems to be missing to attache the one side.
I tried jerry-rigging it by adding a screw where the missing post is and it didn't power up then pop when drawing a shot.
I've seen suggestions and they're all pretty sketchy.
The newer and disappearing version of portafilter isn't cheap, but seems built cheap.
Does anyone know if the portafilter for the HD8325 (Poemia) units works with ours? It looks like it should and those portafilters are available and cheap: Philips Encompass
3 commentaires
You know... even if it doesn't work, parts could be scavenged from the look of it: https://101coffeemachines.info/wp-conten...
par Stan Landers
Encompass didn't answer my question if the Poemia portafilter is compatible. They only said the part to my unit has been discontinued and is no longer available.
Kind of weird.
I'm seriously considering buying one, trying it, and possibly swapping out pieces because the original was more solid.
Someone needs to test that for compatibility. At $28 it's a good solution.
par Stan Landers
I ordered a Poemia part. I paid a few dollars more on Amazon, but returns are easier with them.
I will report back.
par Stan Landers
