Aller au contenu principal
The Samsung NX1000 is a digital smart camera that was released April 2012
Question close
My camara has this black font on the screen.
When I put the battery in the camera, only a green light comes on, the screen gets black (it doesn’t even turn on) and it doesn't let me do any function
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Based on the information provided, it seems that you are experiencing issues with your Samsung NX1000 camera after inserting the battery. Here are a few suggestions that you could try to troubleshoot the issue:
  1. Check the battery: It's possible that the battery may be faulty or not properly charged. Try charging the battery using the camera's charging cable or a separate charger, and then reinserting it into the camera.
  2. Check the battery contacts: Ensure that the battery contacts on the camera and the battery are clean and free from any debris or corrosion. You can use a soft, dry cloth to clean the contacts.
  3. Reset the camera: Try resetting the camera to its default settings. This can sometimes help resolve software-related issues that may be causing the problem.
  4. Check the display settings: Ensure that the display settings are not set to "Off" or "Power Saving." You can access these settings in the camera's menu.
  5. Contact Samsung support: If none of the above steps work, it may be best to contact Samsung support for further assistance. They may be able to provide additional troubleshooting steps or arrange for a repair if necessary.
I hope these suggestions help resolve the issue with your Samsung NX1000 camera. Good luck with your troubleshooting efforts!
Indice 0
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 96
