Why is my screen touching itself
Keeps touching itself
Hi Mathew,
"Ghost touches" as the problem you're having is described, is a result of the phone's processor getting bad data from the digitizer, or touch screen. It's usually a result of a damaged touch screen, as there are delicate connections between the flex cable that goes to the logic board and the glass on which the digitizer circuitry is printed. The glass does not have to be cracked for the touch screen to fail; it's frequently the case that no damage is visible at all.
It is possible for the problem to be located on the motherboard, but since those issues are generally not repairable by us normal home DIY-ers, let's stick to the part we can fix, the screen.
The best chance you have to fix this yourself is to replace the screen, but there are certainly things you can do to try and diagnose the problem before you go ahead and order a replacement screen. Unfortunately you'll have to open up the phone to check those things out. You can disconnect the screen connector, clean it with 90% or higher isopropyl alcohol and reseat it firmly. If that doesn't help, then it's probably time to replace the screen. For that some instructions would be nice; unfortunately iFixit doesn't have a guide for you, but there's a German site called iDoc that does.
Samsung Galaxy A13 screen replacement - repair guide
Good luck; let us know what you find!
I was having this exact problem. Tried everything, even got a new phone. But when the new phone died I dug the old a13 out and accidentally figured out that for some reason the ghost touch problem goes away when the phone is charging. No idea why. Probably not good for the battery to constantly be plugged in. And it's certainly not convenient during times where I'm not near a charger. But as an immediate solution until I can get a better phone plugging it in solves the problem.
I have too the same problem.
When I washed my phone with a tissue, the same thing happened to me.
Depending on what liquid was on the tissue, it may simply need time to dry, or it may be contaminated with the chemicals used and never recover. I'd suggest drying it with a hair dryer for 10 or 15 minutes and see if that helps; otherwise you may end up needing to replace the screen.
Dernières 24 heures : 8
7 derniers jours : 107
30 derniers jours : 609
Total : 3,197
3 commentaires
screen touching not waking...
par Ashok Kumar
Sumenge A13secreen changing
par Abozar Wolasmal
@abozarwolasmal what does that mean?
par oldturkey03
