Aller au contenu principal
La version 2016 de la série d'ordinateurs portables Apple destinés aux professionnels. Dispose d'un écran Retina de 15 pouces, d'une résolution de 2880 sur 1800 pouces, processeur quad-core Intel Core i7, 256 Go / 512 Go /1 To / 2 To en options de stockage, RAM de 16 Go et un clavier équipé deTouch Bar. Sorti en novembre 2016. Numéro de modèle A1707.
20 questions Voir tout
Won't sleep when lid is closed
Hi everyone,
When the lid is closed on this MacBook, the laptop doesn't go into sleep mode. This happens whether it is plugged into the charger or not. macOS has been clean installed and that has not helped.
I believe that it is very unlikely to be software related at all, so I would like to know what parts of the MacBook can cause this. I assume there is some sort of H.A.L.L effect sensor in the top case, but would replacing the top case resolve this issue? (the battery needs to be replaced too so it isn't too bad to do this at the same time.
Thanks, Philip
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Yes your system uses a Hall sensor with a magnet imbedded in the displays lid. The Hall sensor is hidden in the Right side speaker MacBook Pro 15" Retina (Late 2016-2017) Right Speaker
Replacing it should resolve things. But to be sure use a rare earth magnet sliding it along the face area of the speaker area the display should react if not that’s your problem.
Image Replace a right speaker compatible with the Late 2016 to 2017 model A1707 MacBook Pro 15" Touch Bar laptop. Fix issues with sound ouput.
Produit
$24.99
Indice 1
1 commentaire:
thank you. will check that out.
par
Ajouter une réponse
Philip Race sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 96
