Aller au contenu principal
Voici comment réparer votre iPhone 14 Pro. Sorti le 16 septembre, le "plus petit" smartphone phare d'Apple est doté d'un écran OLED ProMotion de 6,1 pouces, d'une caméra arrière à triple objectif, de la 5G et de l'encoche interactive Dynamic Island autour de la caméra frontale et des capteurs supérieurs. Successeur de l'iPhone 13 Pro.
20 questions Voir tout
Use contact cleaner on lighting port and cable terminals
Hi,
Can I use contact cleaner (spray) to clean the lighting port (after removing the lint) and also spray it onto the cable terminals?
Best,
Peter
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Hi Peter,
Contact cleaner is explicitly made for electrical connections to remove corrosion and dirt that may be keeping the connector from doing its job properly. It evaporates completely so as to not leave any residue. So yes, I would agree that this is an appropriate application for it.
Since the port is (or at least is supposed to be) sealed, there shouldn't be a big concern about the cleaner getting inside the phone. I'd probably try and be a bit judicious with the application of it; personally I'd suggest putting it on a cloth or a Q-Tip rather than spraying it directly into the port, but in general it should be okay to use for that. And yes, it'll be fine to spray it on the cable terminals themselves.
Indice 3
1 commentaire:
Thanks, Jerry W!
par
Ajouter une réponse
Peter Hahmann sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 59
30 derniers jours : 253
Total : 9,660
