Why is my saying device over heating and shut down
Why is my phone saying over heating when I open it thet it shut down
@amanuelshiferaw we are now making the assumption that it is not overheating but that you get a false message. First thing I would suggest to do a hard reset. You must backup all your files/pictures/etc since you will lose those. After that, proceed by following the hard reset as listed on here REMEMBER TO BACKUP!
If that did not work, replace your battery and check the charging port on your circuit board. Both of those can cause this error at well. Let us know what you find out. this might work for you
If your Samsung Galaxy A2 core is displaying an overheating message and shutting down, it could be due to several reasons:
1 High ambient temperature: If you're using your phone in a hot environment, it could cause your phone to overheat. Try moving to a cooler place and see if the problem persists.
2 Heavy usage: If you're running resource-intensive apps or playing games for extended periods, it can cause your phone to heat up. Try closing any apps that you're not using and take breaks between gaming sessions.
3 Damaged battery: If your phone's battery is damaged, it could cause it to overheat. In this case, you may need to replace the battery.
4 Malfunctioning hardware: A malfunctioning component inside your phone could be causing it to overheat. In this case, you may need to take your phone to a repair shop to have it fixed.
Here are some things you can do to troubleshoot the issue:
@thetechboss your habitual linking to the same site is considered SPAM. You can have a link to that site in your About page but do not continue to post it in your answers.
layar lcd hitam dan saya tidak tau memperbaikimya
Dernières 24 heures : 3
7 derniers jours : 19
30 derniers jours : 90
Total : 1,506
