Problems after screen replacement
Hey, I replaced the display on my 12 Pro Max with a cheap OLED display because I didn't want to spend a lot of money on it, but the display only lasted some days because it cracked on my pocket, but I kept using it for some weeks, the display was half green and kept turning off (locking the phone and unlocking would fix), then one day it turned off and never turned on again (phone was still working fine, only the display was off), so I replaced again with a even cheaper display (LCD), but this display never worked, only the touch part works, I already tried to clean the connectors, plug them again, force reset the phone, and nothing fixed it, but if I enter recovery mode, the screen turns green (pic below). So, what can be the issue? its possible the first cheap display fried the display part of the board? or its possible the second display to be damaged already? DFU restore have any possible chances to fix this? Thank you for the help!
1 commentaire
Witam, czy udało się naprawić problem z wyświetlaczem, mam taki sam przypadek.
English translation:
Hello, did you manage to fix the display problem, I have the same case.
par Marek Mitrus
