Aller au contenu principal
Replacement capacitor for Lennox icomfort 10f81 Thermostat
I am trying to figure out the replacement Capacitors for the 10f81 thermostat. There was guide created for this but the Capacitors shown don't match what I have in my thermostat. Here is the link to the guide...Correction de l'écran vide Lennox iComfort 10F81 Thermostat. I am attaching pictures of the Capacitors in my thermostat. The Capacitors in question are the "220 HHB. JD4" and the "E 4DB 47 10V".
Update (05/03/23)
Update (05/03/23)
Somehow I sent the same image. Here is the second image.
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
7 commentaires
@burtone It doesn't seem like the pictures went through. Can you they reattaching them? Ajout d'images à une question existante
par
I have tried to add the images. I have uploaded the images but I don't see how to add them to the post.
par
@burtone once they're uploaded, just click or tap on them to add them to the post. You can follow the Ajout d'images à une question existante guide for more details.
par
I have this problem too where did you acquire the capacitors I've been looking after I saw your post not finding where to locate
par
The Capacitors are one the thermostat. I am trying to find a replacement for them.
par
Voir 2 commentaires en plus
Ajouter un commentaire
7 Réponses
Solution retenue
@burtone the first capacitor look like a Panasonic brand based on the markings. It is a 220µF 50VDC (Based on the first "H") surface mount electrolytic capacitor. The second one is a 47µF 10V surface mount electrolytic capacitor. You will need to measure the diameter of the capacitors for replacement since that determines the size of the cap. Anyhow, something like this for Number One and these ones for Number Two
Indice 1
2 commentaires:
Oldturkey03...Thanks for the reply. I appreciate the explanation as to what the markings mean on the caps. It's overwhelming that there are so many of them. I'll measure the diameter to see which one(s) will work.
par
@burtone yes it is because each manufacturer pretty much has their own way of marking their caps series. It does get confusing. Best of luck with your repair.
Repair is War on Entropy!!!!
par
@burtone Tbe blue capacitor in your unit is a United Chemi-Con NPCAP-PXE series capacitor, while the gray capacitors in your unit are Panasonic HB series capacitors. You can use this and this as replacement capacitors. Let me know if you need any further assistance
Indice 1
Afficher le contenu de l'image :
Indice 0
Indice 0
Oldturkey03 and AndrewS...thank you both for your response. Now I understand what capacitors to use as replacements.
Indice 0
@burtone I have iComfort 10f81, it started to show lines and gradually has become blank screen. My app also lost connection, when I tried to reseat the thermostat.
I thought of replacing capacitor before spending on new thermostat. Looks like my thermostat has different capacitors. Attached are the pictures, please let me know the links to the capacitors that would work for this thermostat.
Indice 0
2 commentaires:
@raj39584 These are actually the same brand and series of capacitors that the OP had. You can use https://www.digikey.com/en/products/deta... and https://www.digikey.com/en/products/deta... as replacements. Let me know if you live in a country other than the United States of America and I can send you different links
par
Thanks Andrew, will give a try and let you know if it works.
par
Hi, have any of you had luck fixing these by replacing the capacitors?
I also have broken Lennox iComfort thermostat.
Thank you.
Indice 0
4 commentaires:
I just replaced the capacitors in my lennox 10F81 control screen and an confirm that the process worked just fine. I did tear a leg of the old capacitor but was able to scratch the board to get a soldering point adjacent to the original point. I have a video and can share if you are interested, let me know.
par
@josecastre30495 I think that would be a great idea. I think the best way to do it would be to post it on YouTube and paste the link here. I can then add it to the current guide.
par
Would love to see your video. I’ve ripped a capacitor leg with the pad off the board and trying to figure out how to remedy.
par
Hi All i have the white screen also and the caps On My 10F81 Therm are
2 = 220 hhb k83
1= E 3no 47 10V
Does anyone know what the replacement part numbers are
Thanks Donny
par
Ajouter une réponse
burtone sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 13
7 derniers jours : 29
30 derniers jours : 67
Total : 2,213
