Aller au contenu principal
Disque SSD (Solid State Drive) Western Digital (WD) Disponible en modèles 2,5" 7 mm et M.2 2280 120 Go ou 240 Go
4 questions Voir tout
The ssd is not showing up
The SSD is not showing up when connected to my PC. It has a lot of data in it. I had used it for transferring data. But now it is not showing up when connected to the pc. No drive is found.
Répondre à cette question J'ai le même problème
Indice 1
1 commentaire
SSD card not showing in my PC. The SSD card is ok or not ok. Pls advice. What to do? What is the solution
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Well The BIOS will not detect a SSD if the data cable is damaged or the connection is incorrect. Serial ATA cables, in particular, can sometimes fall out of their connection. Be sure to check your SATA cables are tightly connected to the SATA port connection.
Indice 1
1 commentaire:
but it can detect my other SSD
par
Ajouter une réponse
thrippakulath unnikrishnan sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 23
30 derniers jours : 49
Total : 1,087
