Please leave emotion at the door. Complete, factual statements are more helpful.
If it's blue light then off, it is not a blue light of death. It's normal for the blue light to come on when the console is powered on. If it flashed blue forever, without ever going white, THEN you have a blue light of death.
Since it's not a BLOD, trying clamps (washers?) was not only not possible to fix your problem, but could actively have done some damage.
It also can be helpful to be specific as to how long the blue light stays on.
Simply put, you may have a bad power supply. If it's not the power supply, then it's going to be something on the motherboard associated with power management. Unless you're experienced with this, trying a new power supply is all you can do. Make sure you order one with the same part number as the one you have. Or the alternate part numbers found here: PS4 Dev wiki
A voté
Annuler
Indice
3
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
