Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Informations de réparation et de démontage pour le clavier Logitech MX Keys sans fil. S'identifie par le numéro de modèle YR0073.
Backlight cycling nonstop why?
My 2nd MX keys keyboard with same issue developed after few months. Backlight cycling on and off regardless of time of the day which drain battery really quick. Looks like common issue, found some videos on YT. Fault lay in proximity sensor that can not be disabled by software or key combination without completely disabling backlight which I want to keep. So far I tried.
  • latest firmware
  • blow air to clean dust (sometimes help for little while)
  • turn off&on power
  • change to bluetooth connection
  • change RF receiver
My fix was to disconnect one of the wires inside of keyboard to totally disable proximity sensor.
Logitech do not want to own the issue.
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
In my case, the problem was a poor fit between the foamed conductive contacts and the metal plate, I soldered the wire to one of the contacts and clamped the other end between the screw and the plate, after that the problem went away.
I am very surprised by such a technical solution from Logitech engineers (look at photo):
Indice 0
Ajouter une réponse
Ten Deepfake sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 13
30 derniers jours : 96
Total : 877
