What is this repair part?
Hello,
I’ve replaced the display and Force Touch sensor on my original (Series 0) Apple Watch.
The procedure is a near success: The display inevitably falls out of the case, however. I’ve noted instructions for heating and clamping to no avail.
There are two identical parts included with my repair kit (I also purchased the tool kit). They look like screen protectors but with a large notch in one corner. Are they gaskets for the Force Touch sensor? Adhesive layers? Knowing whether the large-surface-area inside section of this part or the outer ring is the segment to use would be also very helpful.
What is this part?
Thanks!
3 commentaires
Could you add photos of these parts?
par dinoo_fixit
From the photos, it *might* be the adhesive for the display, do you also have a link to the repair kit you purchased? Maybe there is a "included parts" list
par dinoo_fixit
Doing a search for IF308-009-8 seems to return a result of the replacement display and optional, associated “Fix Kit”.
par Jeff_W
